Simple question but I don't know the answer >
Old 08-27-2003 | 11:29 AM
Question Simple question but I don't know the answer
Should we use anything "thread-loc" on the exhaust manifold bolts when installing the exhaust manifold back onto the block??
32 thunder is offline
Old 08-27-2003 | 12:43 PM
Official OSO boat whore
It's a two way street. Sometimes the gaskets need to be retorqued. Sometimes you nne the thread-loc to keep the bolts from backing out. Look at it this way...which ever way you do it will be wrong. Does that help?
Cord is offline
Old 08-27-2003 | 01:26 PM
They're usually impossible to get off even without thread lock. If you are using lock washers, dont bother with the thread lock.
Gary Anderson is offline
Old 08-27-2003 | 01:47 PM
just the opposite...anti-seize...but the above is a correct statement...be sure to check the torques.
audacity is offline
Old 08-27-2003 | 06:53 PM
Allan4
Iron or Aluminum heads??
Use Antisieze if aluminum. We don't use anything if they are iron. Personal preference I guess.
I do use locktite other places on the block though....
Old 08-27-2003 | 10:25 PM
DonMan
I use anti-seize on the exhaust manifold bolt threads, but I use lock-washers too. They are usually quite easy to remove, but don`t back off either.............
Old 08-27-2003 | 11:05 PM
paradigm shift's Avatar
I anti-seize so I can get them off next time. Usually check to make sure they are tight a couple times when I install new gaskets. Once they take a set I have never had a problem with bolts getting loose or coming out. Just my .02.
paradigm shift is offline
Old 08-28-2003 | 11:43 PM
blairjeb
Mercury offers a "anti corrosion grease"that doesn't have such a high aluminum & copper content in it. If you are in a saltwater enviroment,regular antisieze can promote corrosion because of its additives. Just a recomendation.
Old 08-29-2003 | 09:23 AM
Scott's Avatar
Charter Member #30
LMAO a simple question
Poor guy gets 10 different answers
I have Steps & Bubbles!
Scott is offline
Old 08-29-2003 | 10:44 AM
formula31's Avatar
haha good one Scott. I never use anything on the bolts holding my Gils on , but then again, I seem to have them off way to frequently anyways. Dont use locktite, dont use neversieze unless you can check the torque reqularily. My $.02.
formula31 is offline
