Bravo drive gear change to 1.50 >
Old 08-29-2003 | 06:29 AM
Daniel
Default Bravo drive gear change to 1.50
I'm wondering if someone has changed the Bravo drive ratio from 1.36 to 1.50. I have a Cigarette Top Gun
with 1.36 drive, the boat is very heavy and the prop is only a 23" Mirage. I think the 1.50 ratio with a 27" prop
gives me a lower prop slip factor and better top speed.
What's your opinion?
Old 08-29-2003 | 08:10 AM
sterndrivespec's Avatar
you would end up using a 25 mirage if you went to a 1.50 gear ratio.try some four blade props before you tear into the outdrive.hydromotive's work well on that hull and bravo's might also
sterndrivespec is offline
Old 08-29-2003 | 09:17 AM
Dennis Moore
I say that you should go for it. You may be suprised at the difference. Good Luck!
Dennis Moore
Old 08-29-2003 | 09:57 PM
homan
mine is a 28 scarab I had a 1:50on the boat sold it with the other because my 1:36 just had work done and had an Imco shorty but now I couldn't get revs, was told how much faster it would be with a 1:50, so put on 1:50 tried it then 1:50 with Imco stub and after wasting time and a little cash found there is no diff. If i changed props I could compensate and adjust rpm. I called Merc. racing and they said the same he also said the 1:36 was easier on my lower due to blah blah blah at any rate for me ratio didn't mean squat it was just downsizing prop to equal rpm with the same speed seen each time.
Old 08-30-2003 | 07:10 PM
cigarette1's Avatar
Member #2 ....Jeeezz
Run a set of 22" Bravos and the boat will wake up. Night and day difference getting on plane and you'll have midrange punch that you don't have with the Mirage props. Lab the Bravos to run up around 5200 r's and the boat just might even be faster.
G
cigarette1 is offline
bouncedcheque
Drives and Lower Units
4
02-18-2008 09:33 AM
Outlaw Viper
8
05-04-2007 08:34 AM
FunHome
10
09-14-2004 04:03 PM
Jassman
07-04-2004 10:41 AM
26sonic
2
04-16-2003 07:23 AM
