Sticky Steering! Please Help. >
Old 08-31-2003 | 07:14 PM
olysan
Default Sticky Steering! Please Help.
I spent the weekend dodging rain storms at LOTO, and I noticed that all of the other boats I was running with had super smooth steering around the docks.
I'm running an alpha/smallblock combo. The motor is new but all of the accessories including everything associated with the steering system is 1989.
The problem is that my steering is real tight or sticky, and the problem seems to be the worst around the dock, but that might just be where it's the most noticeable.
Has anyone had and fixed this problem? Is this something that goes along with an alpha drive?
Help please!
Old 08-31-2003 | 08:29 PM
Cool
Sounds like a corroded steering cable. Check immediately! You do not want it to let go at WOT
RickR is offline
Old 09-01-2003 | 08:35 AM
FWK
Mike is it a problem just sitting at the dock with the engine off?
Old 09-01-2003 | 09:07 AM
olysan
It does stick when the engines is off.
Old 09-01-2003 | 09:38 AM
Almost definately due for a cable replacement. Mine did the same two years ago. $120 and about 45 minutes did the trick. You notice the "sticking" around the docks because that's where you do all the steering back & forth.
Holy Smokes is offline
Old 09-01-2003 | 12:25 PM
olysan
If it ever stops raining I'm going to take a look at the cable.
Old 09-01-2003 | 06:34 PM
formula31's Avatar
And if you have an external tie bar with heim joints, check that one or both are not siezed. Happened to me, same symptom.
formula31 is offline
MILD THUNDER
0
06-22-2008 05:31 PM
blefever
Do It Yourself, Boating on a Budget
3
01-10-2008 08:13 PM
dreamer
11-13-2006 12:16 PM
two-air
5
06-24-2004 09:04 AM
