Help setting the timing on HP500EFI >
Old 09-01-2003 | 10:55 PM
dhlaw's Avatar
Default Help setting the timing on HP500EFI
Do I need to use a DDT machine to set timing?? The manual says yes, but I set it without but the timing jumps around. Does the DDT lock in the timing?? Help me out, the damn thing is all back together but needs to be timed!!
dhlaw is offline
Old 09-02-2003 | 09:45 AM
dhlaw's Avatar
help
dhlaw is offline
Old 09-02-2003 | 10:21 AM
Breathe Later's Avatar
Dh-
You need to set the ecm into service mode to set the base timing. It can be done with a scan tool or by jumping some pins on the connector. I've got a scan tool that I'd be willing to loan you if you pay the shipping. You could probably do a search on timing to find out which pins to jump too.
Regards,
Mark S.
Breathe Later is offline
Old 09-02-2003 | 11:04 AM
aTX427's Avatar
I believe you jump pins a and b to set the engine to base timing mode.
aTX427 is offline
Old 09-02-2003 | 04:36 PM
order the shunt tool from Mercury, this will only do timing if you want codes get the shunt tool from Renda or you will need the ddt or a lap top...the first is the cheapest
TOPS is offline
Old 09-02-2003 | 08:15 PM
Elite Marine's Avatar
Mercury part # for the tool is 91-805747A 2 all it does is jump the black and white wires on the scan tool connection harness, you can do that yourself with a paper clip or wire.
Elite Marine is offline
alecsammy
1
05-26-2008 05:59 PM
THLWL
1
09-05-2007 07:41 PM
awsomethunder
2
06-15-2006 08:08 AM
Dock Holiday
2
05-21-2006 01:23 PM
