Need some quick TIPS for unlocking a truck with a lock jack
I used to be good at getting into locked cars. I cant tell you the number of times Ive locked keys in cars at the carlot, sometimes running cars. I could get into some cars, like 80s camaros and things easily under 8 seconds.
Today, I have a 97 S-10 Blazer sitting in the middle of the driveway with the keys locked in it. I tried like hell this morning to get in, but Im not sure what Im looking for. It has power locks. Any ideas?
Using a decent slim jim that has always worked before.......
Those S-10s can be tough ! You have to snag the lever on the tumblers.....NOT the slider on the door panel...
put a slight bend in your jimmy so it hits the lever....go slow !! feel around .....you will find it
Is that lever above or below on the lock? I cant remember what they look like inside.
If it ever stops raining this year, I'll go back outside and try some more!
Dont ask Allan !!!!
NO I dont boost cars for a living !!!!
Cant remember top,bottom or side.....just feel around very carefuly & you will feel it......Its all "feel' & picturing how it works.......It has been a few years since i was doing this all the time. just dont even bother with the slide !!! you will just snag wires !!!! & put a bend in the jimmy it helps to get to the lock
Ok, I ended up having to cheat. I called the serial # in to the Chevy garage and had a key made from that. That made more sense than tearing up stuff inside the door!
Birdog, since you can get in them, I need a CD Player for my S-10!!
Kidding!
Kidding!
wompom1
56
12-04-2006 08:29 PM
fountain27ho496
10-17-2003 10:05 AM
