Which Intake Should I Use >
Old 09-03-2003 | 02:00 PM
Pat McPherson's Avatar
Question Which Intake Should I Use
I have gotten some good input from you all, so I'm going to keep asking for opinions on the parts for my project.
I'm converting my 1999 7.4MPI into a Carberated engine.
I have a set of Vortec heads at the machine shop having larger valves install per Dennis Moore's book.
The cam that I will choose should have my engine max out at 5000-5200rpm.
We run 75% in fresh water and always end in fresh water. I believe if I have an aluminum intake hard anodized, it will be fine.
So which intake manifold should I buy???
Holley with 0-5200 rpm range
Edelbrock Performer 0-5500 rpm
Edelbrock Performer RPM 1500-6500 rpm
Edelbrock Performer RPM Air-Gap 1500-6500 rpm
I am leaning toward the Air-Gap being that it is the latest technology, but I thought I would ask you all.
Thanks!!!
Patrick
Pat McPherson is offline
Old 09-03-2003 | 02:13 PM
I know several people that run the Air Gap and are
very happy with the results good overall performance
Bad to the bone is offline
Old 09-03-2003 | 02:56 PM
cuda's Avatar
I've been researching this, and in your case I'd probably pick air gap. My case would be 100% salt, so I may have to go another direction.
cuda is offline
Old 09-03-2003 | 04:09 PM
ForrestC's Avatar
I like the Weiand Stealth intake manifold (Idle-6800 RPM) for marine small-block Chevrolets, and it's an inexpensive intake as well.
ForrestC is offline
Old 09-03-2003 | 05:55 PM
KAAMA's Avatar
Air Gap!
KAAMA is offline
Old 09-03-2003 | 08:02 PM
Thanks to all, the Air-Gap it is.
Patrick
Old 09-03-2003 | 08:06 PM
scarabman34
Air Gap
Rambunctious
5
12-13-2007 09:35 PM
Pat McPherson
14
10-04-2005 10:03 AM
Hy-Velocity
13
02-17-2003 06:31 PM
nobudget
2
04-21-2002 09:53 PM
cigarette39
03-13-2002 02:30 PM
