compression johnson 185 hp >
Old 09-04-2003 | 03:18 PM
johnez
Question compression johnson 185 hp
Hi I have tested compression on a Johnson 185 hp, 1985, it was between 70-80 psi is that very bad or it is normal for a engine who is 18 years old?
If it is very low how do I fix it?
Regards Jonas from Sweden
Old 09-04-2003 | 04:38 PM
Ted G's Avatar
If the test was done with a warm motor, throttle blocked open, and a good battery cranking, then those numbers are too low. You need at least 100 psi, 120-130 is better. You will need to re-ring to bring the numbers up.
www.cbpba.com
Ted G is offline
Old 09-04-2003 | 07:50 PM
Al Oakley
to low 90 psi. is about the limit not worth tunning after that.needs rebuild . i would look for a good used newer moter perfurabley a looper.
spazboz
08-16-2008 10:27 PM
ToTheMax
Checkmate
1
08-15-2007 06:44 PM
Nykamp
Powerquest
0
09-11-2006 12:55 PM
vandeano
7
06-30-2005 12:09 PM
