Milky drive oil >
Milky drive oil
Milky drive oil
Old 09-07-2003 | 10:26 AM
bn
Default Milky drive TRIM oil
I recently noticed that the drive TRIM oil for my port drive is milky and the trimming stops sometimes when bringing it in or out. There does not appear to be any leaks. Can anyone offer any suggestions for trouble shooting this? I would hate to drain it, put new oil in and then have it turn milky again.
(I edited this to indicate trim oil)
bn is offline
Old 09-07-2003 | 10:40 AM
Al Oakley
presure and vacum test.with 21psi.use soapy water and spray around the seals untill you find the leak
.and what kind of drive ? the water pump base is allways suspect in alpha type drives,if it is melted under the wear plate replace it.if it will hold 21 psi. of presure and vacum it sould cure your problem
Old 09-07-2003 | 10:54 AM
bn
The boat is a 2002 with bravo I's. I will give that a try - thanks!!
Brian
bn is offline
Old 09-07-2003 | 11:10 AM
Al Oakley
brovo check the prop shaft seal first . i see them all the time with fishing line wraped up in the seals .that and bent prop shafts.brovos usaly are preaty good on keeping the water out.some times the seals will grove the shafts .some times you can set the seals at a littile deeper are a littile higher to get some more life out of them
Old 09-07-2003 | 06:49 PM
bn
I miss spoke, I meant to say that my drive TRIM oil is milky. Sorry. Could it be coming in through the trim rams or something?
bn is offline
Old 09-07-2003 | 07:54 PM
Audiofn's Avatar
Charter Member #232
It can come through the trim rams, trim lines and also I once saw the connector at the underside of the drive were the hoses go into the gimble assembly crack when some one got a little over zenouls with the tightening!!! You can still use the soapy water trick and trim up all the way and when it gets to the top keep trimming for a couple seconds (not to long of you will heat up your trim motor. As far as the unit stopping I would guess it is suffering from the water being in there. There is a good chance that if you get the water out of the thing that you will be ok but water is not a great lubicator and it does cause rust so I would try and get it out of the unit ASAP.
Jon
Put your best foot forward!
Audiofn is offline
white scarab
14
07-13-2006 12:14 PM
rusking
6
06-29-2005 05:29 AM
cig1988
9
05-07-2004 05:45 AM
bn
Sonic
5
09-10-2003 06:51 AM
