What does a 311 weigh on a trailer? How 'bout a 357?
Can tell you my 272 SR1 , full tank (129 gal) and aluminum tandem trailer and all the misc. B.S. is about 7500/8000.
So by the time you get to 357 , it's gotta be 10,000.
Hope you got a stout tow vehicle
I ballpark my 311 full of fuel and normal lake gear at 9200.
I figure the trailer is 1700.
That makes for 10,900 thereabouts...
I've towed it with a '96 Cummins Dodge 3500 5-speed that was "turned up". That rig pulled it like it wasn't there.
I've towed it with a box stock Duramax/Allison 2500 and it pulled it great but it did "know" it was there.
I've pulled it with a chipped Powerstroke/Auto that was a split between the stock Dmax and the tweaked Cummins.
In all, the Dmax I liked best mainly because of the auto downshift feature of the allison...
Mike,
The 336 I have weighs 8450 dry according to Formula. 160 gal of fuel will add 960. My trailer comes in at 2700 and that puts me at 12110 with a full tank. I'd figure a 311 to be about 1100# lighter (7400# dry, 150 gal tank) and a 357 to be 7-800# heavier (~9000#, 190 gal).
It looks like steel vs aluminum trailer makes quite a difference, but either way, you're looking at at least a 3/4 ton truck to safely pull either. I tow with a 2500 Avalanche (8.1L, 4.10 rear) rated for 12,000 which pulls great but you know it's there, especially on parts of 696.
We're kind of up in the air right now - if the house sells, there is definitely no new boat in our future. OTOH, if we can't sell for what we want, we might just say f*** it and stay here for a few more years, and possibly buy a boat in the mean time.
I dont know where Formula gets there weight numbers from, My 311 on the trailer scaled in at 11300lbs. I weighed the trailer alone at 2800lbs. I had about 30 gallons of fuel, 7 gallons of water and my gear, so I figure the boat weighs about 8100lbs empty, 8300lbs w/gear, and 9200lbs with a full tank. So back to this 7400lb Formula rating, my boat has aluminum heads and exhaust. Does Formula still under scale there boats? I'd like to know because a 353 would sure be a great upgrade, but I dont know if my 9000lb Hydrohoist would hold it. I reluctantly tow it with a 1994 F150 Lightning. I set up the truck w/air bags,12000# receiver, 14000# ball, and a weight distributing hitch. The trailer is a triple axle steel Loadmaster with 6 wheel, 12" drum electric brakes. It tows good to about 65mph, after that it could get a little scary.
