Drive lowers itself - while sitting?? >
Old 09-15-2003 | 02:09 PM
Ran-Dom 32's Avatar
Default Drive lowers itself - while sitting??
During the last few weeks my starboard bravo drive (while on the trailer) lowers itself very slowly - checked the fluid level - it's fine. Now while I was running over the weekend it looses trim on it''s own. Anyone have this problem ? seals going bad? it the hy. rams??
Ran-Dom 32 is offline
Old 09-15-2003 | 02:14 PM
Most of the time, it's the seals in the rams. Buy a kit, cheap and easy to fix.
Gary
Gary Anderson is offline
Old 09-15-2003 | 03:56 PM
Charter Member # 1215
happen to me last week. i think it call the pinion seal or something like that
topgunrcf is offline
Old 09-15-2003 | 04:29 PM
It can also be in the pump
check valving too.
Raise up the drive, mark the
level of the fluid on the pump plastic reservior,
If the check valve is leaking, the level
will rise, if the cylinder(s) seal(s) are leaking,
the fluid will bypass to the other side of the
ram(s)
jt
JaayTeee is offline
Old 09-15-2003 | 04:51 PM
Smitty's Avatar
If no fluid leaks are visible anywhere then you have a bad check valve in the trim pump. Try replacing the fluid in resevoir and see what happens. Sometimes it will clear itself up.
Smitty is offline
Old 09-15-2003 | 08:14 PM
SSComp's Avatar
Had the same problem in a older boat, no leaks, it was a check valve
SSComp is offline
Old 09-16-2003 | 08:44 AM
Ran-Dom 32's Avatar
thanks for the replies OSO - how hard is it to replace the check valve?? what's involved??
Old 09-16-2003 | 02:57 PM
Had the exact same problem. It was the valves in the pump.
Griff is offline
Hydrocruiser
07-09-2006 10:38 PM
OldSchool
08-20-2005 12:00 PM
Elite Marine
0
04-15-2004 02:19 AM
THEJOKER
04-12-2003 04:19 PM
Niuhi
01-12-2002 08:17 PM
