Bravo Low-water pick-up (Cup or Muffs) >
Old 09-16-2003 | 11:38 AM
FunHome's Avatar
Question Bravo Low-water pick-up (Cup or Muffs)
All my other boat's have used the older style muff's.....
But my baja has low water pick-up bravos and I would like to be able to start it out of the water for winterization.
Where can I get, I guess it's a cup??
for the front of the drive??
How much are they??
FunHome is offline
Old 09-16-2003 | 01:03 PM
seanclong's Avatar
Originally posted by Troutly
Any place that sells Merc parts should have them.....about $65 retail!!
Yep. They're hunter orange and look like the business end of a gas-mask with a bungee cord attached.
seanclong is offline
Old 09-16-2003 | 01:11 PM
BRUCE SEROFF's Avatar
My XR lower has a LWP and side pickup. Do I have to buy both flush kits or do they make a kit for this ?
BRUCE SEROFF is offline
Old 09-16-2003 | 02:58 PM
ChrisK's Avatar
Moderator
I have one of the low water pick up connectors... they are BRIGHT orange.. and yeah EXPENSIVE... I paid like $50 bucks for the one I have!
ChrisK is offline
Old 09-16-2003 | 03:07 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
For that kinda dough, might as well go for a mounted hose fitting somewhere in the engine compartment or through the transom. Sonic installs them factory on the swim platform. Could not be slicker.
Sydwayz is offline
Old 09-16-2003 | 03:18 PM
Bruce,
It's another job for duct tape,
I've used duct tape to cover the
4 holes in the front of the gearcase,
then use the ear muff flushing attachment.
jt
JaayTeee is offline
Old 09-16-2003 | 03:54 PM
Roger 1's Avatar
Originally posted by jt29olhp500s
Bruce,
jt
I`ve done it the other way around, using a cup and taping up the side pickup holes.
Roger 1 is offline
Old 09-16-2003 | 05:39 PM
convincor's Avatar
http://www.perko.com/flushpro/flushpro_body.html
boatfix.com has them for $46.00
shop around, you might find cheaper.
Or, just pull the hose off from the inside at the transom assembly and stick a hose inside you intake hose.
you could put some fittings into the bottom of a 5 gallon pail and fill it with antifreeze.
convincor is offline
Old 09-16-2003 | 06:23 PM
Turbojack's Avatar
Bruce,
jt
This is the way I do it. Just remeber to remove the duct tape when you are done.
Turbojack is offline
Old 09-16-2003 | 07:18 PM
Bought an Imco low water pick-up flush kit from www.cpperformance.com . Fits like a glove. Good price, fast delivery!
Glenora is offline
