Removing 3M 5200 may be possible >
Old 09-16-2003 | 10:56 PM
Mr. Demeanor
Default Removing 3M 5200 may be possible
I just ran across this on Bomar's website and thought it might be useful if anyone is ever searching an answer.
There is a product on the market called Anti-Bond 2015 that may help. Anti-Bond 2015 that maybe the solution. Anti-Bond 2015 can be sprayed on 3M 5200 causing it to debond without any delamination of the boat's gelcoat
I have no experience with this stuff, just copied and pasted.
Old 09-16-2003 | 11:08 PM
Ted G's Avatar
Oh, that stuff is the shiznit. But be very careful what else it touches-lots of stuff dissolves if it gets on it(not fiberglass though). It really softens up the 5200 and with a little patience you can remove anything.
www.cbpba.com
Ted G is offline
Old 09-17-2003 | 06:50 AM
Raypanic's Avatar
I have used it, It does soften the 5200 but not deep in you have to penetrate it to get it to let go.
I removed my muffler tips last spring with a torch and a little elbow grease. I just the other day was cleaning the 5200 off with a scraper and tried some spray "brake cleaner" it seemed to work better than the anti bond. You may want to give it a try too. I was shocked. I think I will try some on a new 5200 test patch to see what happens too.
Ray
Raypanic is offline
David Stotz
Do It Yourself, Boating on a Budget
13
03-19-2008 07:17 PM
Scarab3DMC
2
05-28-2006 08:32 AM
Fast Forward
6
05-01-2006 08:40 PM
rv
11-17-2005 06:29 PM
Cord
09-24-2003 08:27 AM
