Checking valve springs
I've got 250 hours on my heads and I figure it's about time to check the valve springs. I've noticed that you can buy a Valve seat pressure tester from Moroso and check them with the heads/springs still on the engine. Is this a sufficient way of testing them, or is there something else I should also consider?
Thanks in advance..
Thanks in advance..
Steve Gresham
'03 Donzi 33ZX
Steve Gresham
'03 Donzi 33ZX
It's not the most accurate way of doing it. Depending on the way you hold it, your readings may be off +/- 10 lbs. Also your exaust manifolds may get in the way. Mine did. It's better than nothing. A friend that drag races uses one between rounds to do a quick check. Of course his cam has about 1.000 lift so he needs to.
Originally posted by checkmate454mag
As far as I know, Moroso only makes a valve spring pressure tool that works on roller rockers. I don't think you can use it on stamped steel stock rockers.
Steve Gresham
'03 Donzi 33ZX
Steve Gresham
'03 Donzi 33ZX
The valve spring tester works good, but typically its used in a comparison mode. IE when you check the srping pressure ever set period you get a trend and when it changes then you know their is a problem. When we raced a sprint car we saved many valve train issues with the spring checker. We checked them every race. I check my springs every 10 to 15 hrs in the boat.
