Go Back  Offshoreonly.com > Owners Forum > Powerquest
Draining Oil... >
Draining Oil...
Draining Oil...
Old 09-21-2003 | 07:28 AM
Default Draining Oil...
I use a 12 volt pump, small units that have a hose to connect to the dip stick and drain hose into jugs.
The problem generally is that one end or the other of the hoses end up comming off the pump in process and oil splatters all over the place.
The fittings that hold the hoses on are cheezy and leak.....plastic.
What are you guys using to drain oil?
Thanks.
Jeff
JeffGrice is offline
Old 09-24-2003 | 08:02 AM
MACTONITE's Avatar
Default OIL DRAINING
JEFF,
Most of us out here probably use the same method you do. I guess it's just a matter of finding a good unit and checking all your fittings before you use the unit each time. My boat was set-up from the factory with automatic drain system. There is a pump mounted under port side of rear bench that is connected to draqin tubes that run to the bottom of the oil pans. Makes draining the oil a snap!
Jeff, do you keep your boat in Venice Shores ?
Michael
MACTONITE is offline
Old 09-24-2003 | 04:50 PM
Michael, yep, Venice Shores, on Windmill - where r u?
Jeff
Old 09-24-2003 | 05:22 PM
Michael-email me at [email protected]...Jeff
Old 09-29-2003 | 07:46 AM
MACTONITE's Avatar
Default discussion on rally
Jeff,
I just sent you an email to your home address.
Michael
MarkDonzi
1
05-28-2007 09:57 AM
US1 Fountain
18
03-25-2007 06:50 PM
tblrklakemo
05-30-2006 11:44 AM
mcraymond3
16
11-16-2004 08:13 AM
rbtnt
1
12-06-2002 12:29 PM
