Convert 496Mag to 496Ho >
Old 09-21-2003 | 08:04 PM
bcoffield's Avatar
Registered User
Default Convert 496Mag to 496Ho
What would it take to convert a 496 (375hp) to a 496 (425) other than the Cam and ECM?
What do you thing it would cost and do you thing it would be worth the 50HP?
How much top end is 50hp worth?
bcoffield is offline
Old 09-22-2003 | 10:46 AM
CigDaze's Avatar
Depending on serial number, you would also want to change the crank, but is not imperitive. The older models were cast and forged, for the base model and HO, respectively. Nowadays, they are all cast, so it's not something you need to worry about too much unless you plan more upgrades later. Other than that, you are correct with cam and ECU change.
50 hp might get you 3 to 4 mph, 5 tops.
CigDaze is offline
Old 09-22-2003 | 01:42 PM
I heard they only run about 3-5 mph faster than the 375hp...The upgrade new is about 6 grand I think, so you would think there is more to it than the cam and ECM????
bcolmsted is offline
Old 09-22-2003 | 02:19 PM
bcoffield's Avatar
Registered User
bcolmsted - good point!
I priced the two parts. Cam $500, ECM $1400 as priced for both the 375Hp and 425Hp. What I did find out is what Baja Daze stated, depending on the serial number of the HO the crank shaft is either $5,608.89 or $1,203.44.
If it is true that the newer verisions are coming with the same crank than what are we paying 5K plus for?
Old 09-22-2003 | 02:35 PM
bcoffield
I have a 375 hp and very happy with it...Most insurance rates go up considerably above 375 hp...As far as the cranks all the same now, I only have heard what bajadaze stated..
I`m not touching mine till warranty is up..
Old 09-22-2003 | 06:07 PM
bcoffield's Avatar
Registered User
If this is true that both the 375hp and 425 hp have the same crank than why the 5K difference in price. Is it just the fact that we will pay more for the extra ponies?
That's a $100 per pony...anybody else?
Old 09-22-2003 | 08:27 PM
bn
I am very interested in finding this out too. I have a pair of 496 mags that I wouldn't mind getting a little more hp out of.
bn is online now
Old 09-23-2003 | 07:54 AM
Thats about it cam and computer and warranty.
HPJunkie is offline
Old 09-23-2003 | 11:02 AM
Kentz
HO's having cast cranks?, not as of 03 models. Where merc get's there blocks
http://www.gm.com/automotive/gmpower...p_brochure.pdf
Old 09-23-2003 | 11:31 AM
bcoffield's Avatar
Registered User
HP1 496mag 375hp (CAST)
