need new prop have more hp >
Old 09-24-2003 | 03:41 AM
excalibur al's Avatar
Angry need new prop have more hp
i have a26.4ft 24 dead rise,boat .brovo 1 drive,496-560hp what would be the best prop to run .and pitch can some one help me.
excalibur al is offline
Old 09-24-2003 | 04:58 PM
throttleup's Avatar
What is the year, make and model of the boat....
What is the relation of the prop shaft to the bottom of the hull...
Weight of the boat...
What is your RPM is the 560HP...
What props have you run so far and what type of results did you see!
Julie
Throttle Up Propellers
877-842-6855
throttleup is offline
Old 09-24-2003 | 05:18 PM
hi julie its a wellcraft excalibur 2001 weight dry is 5000 lb with fuel and accessarys about 6000lb ,going to try a 23 pitch 3 blade mirage tomarrow, just got it done . dino 5200 rpms 560 hp .
Old 09-25-2003 | 08:06 AM
throttleup's Avatar
Call me with your numbers.
WOT RPM and Speed.
Note the boats attitude......bow lift...stern left and performance with the Mirage Plus.
Julie
877-842-6855
Old 09-25-2003 | 09:45 AM
throttleup's Avatar
WOT RPM and Speed.
Julie
877-842-6855
Old 09-25-2003 | 12:21 PM
muffman's Avatar
Yesterday was my first time back in the water with my new 496 HO in a 26 corsa I spun a labbed 26 hydromotive @ 5000 rpm a 70.4 GPS
muffman is offline
Old 09-25-2003 | 07:00 PM
homan
Excal., if you need a 22p bravo 1 I have one just redone
Old 09-25-2003 | 10:35 PM
HOUSTONPROP's Avatar
Default Re: need new prop have more hp
be glad to help if you will let us,Darin >281-580-7767
HOUSTONPROP is offline
Old 11-23-2003 | 10:44 PM
crmax's Avatar
glad to see another excalibur owner
Im in ohio and have a labbed 23" mirage plus if you want to do some testing in the spring let me know [email protected]
http://erienet.net/~russclara/boat.html
crmax is offline
Old 11-24-2003 | 01:25 AM
puder's Avatar
speel chekk this fokker!
25 3 blade or a 24p 4 blade
Pardon me, while I whip this out!
puder is offline
