1.2??? gear ratio's >
1.2??? gear ratio's
1.2??? gear ratio's
Old 01-07-2002 | 01:17 PM
aTX427's Avatar
Post 1.2??? gear ratio's
Does anyone know what gears are required to achieve 1.2 ... gears in the bravo? I think you utilize standard 1.36 in the upper but I am not sure about the lower.
Thx BC
aTX427 is offline
Old 01-07-2002 | 02:48 PM
Cattitude's Avatar
Post
BC- I'm pretty sure Chris "Sterndrivespec" would know- the drives he's selling were originally set-up with 1.12 I think, so i know he's familar with changing the ratios- 315 676 2979. Good luck!
Cattitude is offline
Old 01-07-2002 | 07:36 PM
rbtnt's Avatar
Post
I just bought some lower gears from Sterndrivespec that will have an overall ratio of 1.25 with 1.50 gears in the top. He told me if I put the 1.36 gears in the top, I would have an overall ratio of 1.12.
I'm looking at putting the heavier 1.50 gears in the top. The 1.25 overall ratio will help with prop size.
[ 01-07-2002: Message edited by: rbtnt ]
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 01-07-2002 | 10:53 PM
merlin540
Post
you will find that the more you choke down on rpm with that gear ratio you boat will lose a lot of punch in the midrange and you put more stress on the drive. BEEN THERE DONE THAT. try to set the boat up so that it like rpm. the engine will take more that the bravo. thats the way im going next year in both of my cats. just my 2 cents worth. see ya
Old 01-08-2002 | 09:50 AM
sterndrivespec's Avatar
Post
you can change the gears in the gearcase to end up with a 1.12 or a 1.25 overall ratio.i have some that are slightly used i can sell cheap
sterndrivespec is offline
Old 01-08-2002 | 10:19 AM
rbtnt's Avatar
Post
merlin 540, thanks for the input, but I'm out of rpm with the hydraulic lifters
sterndirvespec - is it possible to get an overall 1.36 ratio with 1.50 gears in the top? This would be in an XR drive.
[ 01-08-2002: Message edited by: rbtnt ]
rbtnt is offline
Old 01-08-2002 | 10:52 AM
Goodfella's Avatar
GOT MERC?
Wink
If you are running a 1.50-1 upper ratio on a XR Bravo I. You can change the lower gear set to achieve 1.35 or 1.26 overall ratio. These lower gears are genuine Mercruiser. If you a running a upper ratio of 1.36-1 than you can achieve a even lower overall ratio.
Goodfella is offline
Old 01-08-2002 | 02:42 PM
Post
correct if you have a 1.36 upper you can get down to a 1.12
Old 01-08-2002 | 07:33 PM
aTX427's Avatar
Post
Thanks for the feedback.
aTX427 is offline
Old 01-09-2002 | 05:10 PM
Post
Can I get to 1.26 with my 1.36 drive with only a lower gear change and not touch the uppers? Or will it take me to 1.12?
cobra marty is offline
