How long will aluminum heads and intake last in freshwater?
I've ordered AFR aluminum heads for the T-540's I'm building. I asked them to hard anodize the heads, but what about the intake? Too Old gave me a pair of Edelbrock Performers with the boat. They'll probably be a little on the restrictive side but I've got hatch clearance constraints.
Can you buy aluminum intakes already hard anodized, or otherwise internally protectedf rom corrosion? Roughly, how long does a pair of unprotected heads and intakes alst in freshwater vs. how much longer (if any) they will last with hard anodizing or some other method of corrosion prevention?
I've been running the same automotive grade aluminum intake on my setup for almost 25 years in fresh water and there is no evidense of corrosion. There is however, the typical calcium buildup in the water passage. I've never had aluminum heads.
run salt away on then after each use, that stuff works great for salt are fresh water, and drain the motors in the off season and you should last for several seasons, you can also buy anodes that screw into the water fittings on the heads and intake they help a lot
There is a lot of industrial equipment that uses fresh water in applications such aluminum water tanks, aluminum pipes, aluminum valves, irrigation pumps etc. This equipment uses magnesium anodes to protect them from corrosion.
Bolting a piece of magnesium inside the cooling system of your engine will protect it from corrosion. As long as all of the aluminum parts on your engine are electrically grounded together the magnesium can be installed anywhere inside the cooling system.
Magnesium anodes are more effective than zinc anodes at self sacrificing but magnesium dissolves very quickly in salt water so most anodes are made from zinc. In fresh water, magnesium is the best anode.
Dennis Moore
Dennis Moore
I purchased a set of anodized Brodix BB-2 s. They do a hard coat anodize which covers the inside and out. It is a green color. They say you can use the heads in salt water. The cost is about $500.00 extra a set
1BIGJIM
1
04-02-2007 06:23 PM
Dave1972
6
12-09-2003 02:16 PM
