Loosing RPM's   HELP!! >
Old 09-29-2003 | 02:54 PM
BajaBennett's Avatar
Question Loosing RPM's HELP!!
Trying to help a friend work the bug out of a new engine. New block (454), forged crank, new pistons, etc., new Dart rectangular port heads, Holly (800). Original Merc. ignition (454 Mag.). Idles fine, gets on plane fine up to about 4300 rpms, then it starts slowing down. Back off and wait about 30 seconds and it will go again. We checked fuel pressure and have about 4 lbs. when running. Is this enough????
Any ideas guys. My friend had this engine built thinking it would be very dependable. However, it just won't run. Any thoughs would help.
Dail
BajaBennett is offline
Old 09-29-2003 | 04:17 PM
mats's Avatar
Sounds like lack of fuel. The float bowl gets emtied at WOT and when you slow down it is refilled again.4 psi is on the low side. Have you checked if the fuel pressure goes down at WOT?
mats is offline
Old 09-29-2003 | 08:49 PM
mats,
I'm thinking fuel too. The engine builder went out with us this afternoon and did a vacumn check. He got 8 - 10 and said it should be 10 - 15. So we pulled the intake. No indications of a leak. We had sprayed carburator cleaner around the intake earlier thinking there might be a leak, with no results. I am thinking we need a constant 7 lbs. of fuel pressure to feed this thing
Dail
Rocko C
7
08-27-2007 12:07 PM
FX10
Superboat
15
11-21-2006 06:23 AM
Strip Poker 388
04-09-2004 09:07 PM
97BossHammer
01-24-2003 12:50 PM
