OK Motor heads! 454 4 bolt... >
Old 01-10-2002 | 06:17 PM
mlitefan
Post OK Motor heads! 454 4 bolt...
I am looking at an engine put together by a local engine shop (they do a ton of local circle track stuff as well as some boat engines)
Not sure of ALL of the components but here is what I know now...
454 4 bolt main, line honed, bored 30 over, balanced, decked and has an "Eagle" kit (not sure what that is but it consisted of pistons, aftermarket rods, etc). File fit rings, roller cam (not sure which), roller lifters...All good stuff.
Not been on a dyno but a rough guestamate is 475 to 500hp. Only issue is it is most likely high compression (at least 10:1). Aluminum 8 quart oil pan.
More details to come...Never been cranked (built 2 years ago and buyer skipped town).
Less carburetor, he is asking 5650.00...
Any thoughts or things I should look for/ask about? I thought a set of Stainless or Gill exhaust and I am in business! High compression scares me though...
Old 01-10-2002 | 06:55 PM
traviss's Avatar
Post
get the specs on the cam, to see if the cam is even close to the rpm range for the boat.. I have run 10:1 comp ratio on the last 461 we had in the boat, ran 93 octane with no problems..
traviss is offline
Old 01-10-2002 | 07:02 PM
turbo2256
Post
Find cam specs and whats been done to the heads. Its easy to over port them for marine use and alot of torque could be lost at the lower rpms a boat uses.
Old 01-10-2002 | 07:04 PM
mlitefan
Post
I am going to stop by the engine shop tomorrow and get the spec sheet on the engine. I appreciate the help!
I will post as soon as I get it.
Old 01-10-2002 | 07:47 PM
Vinny P's Avatar
I hate the winter!!
Post
If the motor was built 2 years ago, I would find out how it was stored. Rust can form in the cylinders, no telling what else can happen internally. BEWARE!!!
Vinny P is offline
Old 01-10-2002 | 08:06 PM
Official OSO boat whore
Post
That compression ratio sounds aful high. I've also been repeatedly told that you can not get 500hp from a N/A 454. For exhaust, I suspect that you are going to need a true header for scavenging.
Cord is offline
Old 01-10-2002 | 08:26 PM
Vinny P's Avatar
I hate the winter!!
Post
Cord;
You are wrong about your horsepower numbers.
Vinny P is offline
Old 01-10-2002 | 08:30 PM
Post
two years??????? I would wonder! I had 454 mag rebuilt,If I had it to do all over from the get go I thing I would buy more hp in the crate,somewhat worry free for sometime to come.just my .01 cent don't have .02
FloridianSon is offline
Old 01-11-2002 | 09:17 AM
formula31's Avatar
Post
And thats a lot of money unless it has lots of top line stuff in it. You can get a crate 502 for that money cant you?
formula31 is offline
Old 01-11-2002 | 10:46 AM
Wally's Avatar
Were doomed!
Arrow
Also make sure the centerline of that cam is good for marine use!!! You dont want to be getting reversion into a motor you just bought!!
-Wally
Wally is offline
