Thinking I need more power!
Here is the deal I have a Donzi 26Zx with a 454 (385 HP) and need to get more power out of it. I am contenplating the following:
1) Whipple Charger (cost)
2) Stainless Marine Exhaust
3) Cam
Give me some ideas????
3) Cam
Give us an idea of what your objective is. How much faster do you want to go? That will determine how much more power you will need.
I am running around 4800RPM at 68 mph and my problem is I am running a 1.5 Bravo drive with a 24 pitch 4 blade prop. When I put more than 2 people in the boat it barely planes off. I want the boat to have a good hole shot but don't want to go down in prop size because I don't want to lose the top end. I would like to keep it around 4K or so. Any ideas would be appreciated!!!
Donzi- your goal is admirable and common but you are falling in a middle ground for which there are no real answers. Cam and exhaust can easily eat 4K if you include labor- seat of the pants will show a little- GPS will likely show less(2-4). A whipple is a little over 5k just for the kit (I'm a distributor), no labor, prop, gages, hyd. steering (You will need it with the speeds you see) transom or LWP if you don't have one etc.
In short, I would look at getting all you can from labbing your prop through York which will help some at a minimal cost ($200ish), perhaps a computer reprogram from Arizona Speed and Marine (I'm guessing at 500ish) This will help bang for the buck wise. Otherwise go Whipple, it's not that much more $ than cam and exhaust but the performance difference is awesome. Good luck. you really just need to weigh how much bang you want and what are you willing to pay to get it.
So you think you need more power! Don't you know that's when all the trouble starts? Why can't you just be happy with the speed you've got like the rest of us!
Seriously, that's a big boat for a single engine, so you can't do anything that will cost you bottom end torque. One step up on the cam and you may not get up on plane at all. I agree with Cattitude, you need to save up for a blower.
Agree with Cat. You're a little under budgetted. You culd do exhaust manifolds and ss risers $2k, MSD ignition, Air filter and ECU reprogram $1.5k. Will probably pick up some low end and 300rpm on the top. You'll hit low 70s then prop work $500. Your $4k is gone.
you could get a used (non whipple) blower the whipples are good but they are pricey.
Off Topic but are you ever at the sanhole in Oyster Bay? Or in Oyster Bay itself? I have seena 26' donzi flyind around a bunch of times.
Pardon me, while I whip this out!
Yeah, I go over to the sand hole all the time in L.I., I am there almost every weekend. My boat is white with the Red and Black stripe on it. Well I gues I will have to way my options. Does anyone think that just exhaust and a labbed prop will get me a better hole shot? With the 454 Donzi wasn't sure which prop to run, first they said the 24 4 blade and than they changed there monds and told me the 22 4 blade. I tried the 22 but I lose about 6 to 8 on the top end but have a great hole shot. What do you think that the boat would do with the whipple on it, miles per hour and hole shot?
