Fogging MPI engines with cool fuel >
Old 10-08-2003 | 03:00 PM
Default Fogging MPI engines with cool fuel
In the past I've just sprayed
fogging oil into the throttle body
when winterizing.
I heard somewhere that you can
remove the water separator/ fuel filter
and pour some 2 cycle oil into it, then
reinstall and run til it starts smoking.
Anybody heard this ?
I remember on the VST engines,
the service manual said to add
2 cycle oil to VST for fogging.
jt
JaayTeee is offline
Old 10-08-2003 | 09:48 PM
Dennis Moore
I like the oil in the gas but pour some Fuel Stabilizer in the tank and run it through the engine before shutting it off for the winter. The fogging works great through the throttle valve on an EFI.
Dennis Moore
Old 10-08-2003 | 10:10 PM
HOUSTONPROP's Avatar
Talking JT 29OLHP500s
J.t. Sorry to hear that it's that time of the year.
Are you into to snowmobiles at all.I sold mine to your friends, when I, moved to Texas 12 years ago. I sure miss them, they helped speed up the long winter day's there.
I think it was in the 80's here today ,just perfect working or boating weather.
Later Darin
HOUSTONPROP is offline
Old 10-09-2003 | 04:27 PM
mr_velocity's Avatar
Originally posted by Troutly
Merc recommends on the 500 EFI to use 50/50 mic of Sta-bil an 2 cycle in the fuel/water separator. I've done this and it is very easy. This way the entire fuel system gets treated. I'm told shooting a fogging oil through the throttle body will not get the entire fuel system.
That's the only way to do it. Spraying oil into the throttle body will mess of the MAF and MAP sensors.
mr_velocity is offline
Old 10-09-2003 | 05:46 PM
Ric232
Does MAF refer to mass airflow sensor? These are speed density systems.
rhsj2006
15
08-27-2008 12:02 AM
Rage
0
05-06-2008 11:00 AM
Pismo10
3
09-05-2006 06:40 AM
mjb
12
03-12-2006 05:49 PM
Rage
13
01-14-2006 05:53 AM
