Blower trivia >
Blower trivia
Blower trivia
Old 10-13-2003 | 11:28 AM
X-Rated30's Avatar
Default Blower trivia
Most roots type blower makers use numbers to describe their blowers (ie Holley 420, Littlefield 10/71, B&M 250, etc.)
These are not just model #s. What do the numbers mean? (Long answers accepted, so weigh in mcollinstn!)
X-Rated30 is offline
Old 10-13-2003 | 11:43 AM
formula31's Avatar
Well, I know one part of it. The GM blowers are from Diesels. 2-71 is a from a 2 cylinder 71 cu/in per cylinder engine. 6-71 from 6 cylinder 71 cu/in per cylinder and so forth. There are 110 cu/in per cylinder engines-very old, 53 cu/in per cyinder engines-newer and the 71's.
formula31 is offline
Old 10-13-2003 | 11:55 AM
Official OSO boat whore
Ok, next trivia question...of the popular blower sizes available today...which were never available as a GM diesel?
BTW-I believe all the numbers are relating to their displacement, not just the GM engine series.
Cord is offline
Old 10-13-2003 | 12:18 PM
I'm withcord on the 144, 174, 177, 250, and 420's.
Gary
Gary Anderson is offline
Old 10-13-2003 | 12:50 PM
X-Rated30's Avatar
Gary
Meaning what?
Old 10-13-2003 | 01:08 PM
later's Avatar
i would think that the only blowers used on automotive type engne were the 6-71 and the 8-71. beyound that the 10-12-14-71's were aftermarket blowers the used the standard means of measurement i dont think the smaller blower 171 and 144 are a diesel direvetive.
later
later is offline
Old 10-13-2003 | 01:19 PM
Oops, kind of short on that answer/guess.
That series is numbered by displacement. cu inches of air in 1 revolution?
Gary
Old 10-13-2003 | 01:24 PM
formula31's Avatar
All pretty much right so far. Back in the old days we did fit a 2-71 blower to a motorcycle engine.
Old 10-14-2003 | 07:39 AM
Offshore Addiction
alright,reading an encyclopedia one day,helping my kid do his homework I came across this,in what application did they use transmisions to actually switch the speed of the superchargers while underway and why? and wouldnt that be kick butt in a boat!
Old 10-14-2003 | 07:56 AM
Iggy's Avatar
I know the WWII Merlin engines had two speed superchargers (the P-38 Lightning had turbos in place of the centrifugal superchargers). The big bombers with radial engines had mulitple settings for their turbochargers. Some bombers, like the B-29, had both turbos and superchargers.
One reason for multiple blower speeds, for aircraft, is to have the same power at high altitudes as well as at sea level. The higher the altitude, the lesser air density, more boost is needed to maintain power level.
Iggy is offline
