Any performance gain with AMSOIL >
Old 01-16-2002 | 10:39 AM
BajaRunner's Avatar
Post Any performance gain with AMSOIL
Has anyone heard of a performance gain by switching to AMSOIL? I have heard that if you change your outdrive oil and Engine oil you can gain 100 rpms? TRUE/FALSE????
Jason
BajaRunner is offline
Old 01-16-2002 | 04:09 PM
BajaRunner's Avatar
Post
Another thing. Is it true when you switch to Synthetic, you cant switch back?
Old 01-16-2002 | 07:22 PM
Post
Any questions about oil on this site and you'll open a can 'o worms - here's my thoughts:
Lubricity of a synthetic may be a little bit better that petroleum, but not for long. The big enemy is contamination and synthetics contaminate just as fast as petroleum. The secret is to change your oil often. I change mine every 20 hours or so with 40W petroleum based oil. I've had no oiling problems or undue wear. I have money left over to buy beer.
As far as Amsoil goes, good stuff, just not necessary in my mind.
I'm in Austin as well, keep in touch.
John
JohnJan is offline
Old 01-16-2002 | 11:03 PM
Scott's Avatar
Charter Member #30
Post
Troutly,
Man your all over this board tonight!
I have also heard that you may have less friction giving you some more rpm's. I run it in my motors just for insurance if they run hot the syn should hold up longer than regular oil. As far as the drives I'm happy running Merc High Perf.
Do a search on Synthetic drive oil and you may find some good info. Just be prepared to spend a looooong time reading. (subjects been covered to death).
I have Steps & Bubbles!
Scott is offline
Old 01-17-2002 | 08:52 AM
BajaRunner's Avatar
Post
Thanks for the responses. I think Im going to give it a try.
John, you go to Travis often?
Old 01-17-2002 | 12:38 PM
Post
Every chance I get. I've got a red 26' Thoroughbred with tan and gold stripes.
JohnJan is offline
Old 01-17-2002 | 01:59 PM
BajaRunner's Avatar
Post
Ive got a 27 foot Baja Force that says "Danger Zone" down the side. It also has a radar arch.
We should get together sometime
Old 01-19-2002 | 10:04 AM
boathead's Avatar
Post
bajarunner,
If you do decide to use amsoil(which I use in both engine and drives)or any other brand of aftermarket oil in your outdrive, make sure you use a GL-4 rated gear oil, NOT GL-5, the phosphorous additive in the GL-5 will attack bronze, the same goes for your tow vehicle transmission(if it's a manual, that is) most have bronze synchronizers.
Paul
boathead is offline
Old 01-20-2002 | 10:00 PM
Post
OK boathead, I run Amsoil in my PQ.. well only in the outdrive I use the series 2000 75w90 it works well is it the right stuff ??
Say high to good old BR for me. later
powerqrudy is offline
Old 01-24-2002 | 01:24 PM
stingray
Post
The only advantages to synthetics are they take longer to break down (good for those not good about changing their oil frequently) and their heat tolerance is better. Other than that, if you change regularly it's a dead heat...
