Dart Iron Eagle Heads & Plugs
After pulling my heads to repair broken pushrod guide plates I noticed that the short style spark plugs I was told to use on the Dart Iron Eagle Heads were not long enough to reach the combustion chamber.
I called Dart and they recommend the 3/4" length, gasket style plugs for the Iron Ealge heads.
Attached is a picture of the plugs, it appears that 3/16" of the plug is actually in the combustion chamber. Is this correct?
What plugs are other running in these heads?
Thank You,
Kirk
Thank You,
Kirk
