MK4 to MK6
Old 10-19-2003 | 07:42 PM
Default MK4 to MK6
Is it possible to replace a Mk4 big block with a Mk6 without a major rework? What's required besides a different oil pan ?
sparky1957 is offline
Old 10-19-2003 | 10:19 PM
mcollinstn's Avatar
If you're talking a longblock swap, then the fuel pump is your only issue. The other different parts will already be on the longblock.
mcollinstn is offline
Old 10-20-2003 | 08:17 AM
ursus
crank is different but you can get an adapter for the gen VI block to use a MKIV crank otherwise the flywheel/harmonic damper will also be different if you change to a gen VI crank, alternator/PS brackets need holes redrilled (bolts are larger and offset about 1/8" so you can redrill the hole off center with a drill press to fit) gen VI is missing the hole for the front mounting bolt of the starter motor if the mkIV block has the old large starter( there is a 1/2"npt pipe thread plug in this location so you can tap a 1/2 " plug for the 3/8 bolt if you want to use the original large starter), the seawater pump will need to be shimmed to line up with the serpentine/ V belts, timing cover is different, Different oil pan as you knew and different dip stick
nothing major just a few idiosycracies
IRONMAN
Do It Yourself, Boating on a Budget
2
02-26-2008 09:00 PM
Big Block Billy
3
02-22-2008 08:41 PM
