Deadrise 21 degrees vs 24 degrees? >
Old 11-15-2003 | 08:41 AM
Default Deadrise 21 degrees vs 24 degrees?
Looking at a boat. Can someone tell me the avantages of a 21 degree deadrise vs the 24 degrees? Which is faster? Which rides best in rough water?
Thanks, Jim
JimmyBaja is offline
Old 11-15-2003 | 08:56 AM
Pat McPherson's Avatar
Big Difference!
Most rough water deep V boats are 24°. So if you are looking to play in the rough, go that route. The only down side with a 24° that I can think of is that you have a big wake at low speeds; no good for water skiing.
Patrick
Pat McPherson is offline
birdog's Avatar
24 is better in the rough....21 may be faster in smoother conditions...flatter bottom
birdog is offline
Old 11-16-2003 | 07:35 AM
Folks,
OSO'ers are great. Everything a person could want to know.
Thanks for all your info.
Jim
Old 11-16-2003 | 07:41 AM
Ric232
Jimmy,
It sounds as if you are comparing an H2X against some other model. In addition to the 21 deg deadrise in the H2X, there are no stand-up bolsters (you basically sit on the floor). The stand-up bolsters are another big plus in rough water.
Old 11-16-2003 | 12:42 PM
SledgeHammer's Avatar
I too get the impression he is looking at an H2X, and if comparing to a 24 Outlaw, the H2X will blow the 24 Outlaw away until it gets pretty rough. No question the deeper V is better in the rough.
SledgeHammer is offline
Old 11-16-2003 | 09:51 PM
Actually I am comparing a 290 Sport to my older 280 Force.
Thanks, Jim
Old 11-17-2003 | 11:20 AM
liquid lounge
21 degrees used to be considered a deep V and if properly designed would be just fine for most inland lakes...if you boat in relatively smooth, uncrowded lakes, you will be happier with a more moderate V; less power to get out of the hole, less bow rise, more stability at rest and underway[i.e. passenger movement less noticable], normally better acceleration to top speed. I don't think that a semi V is necessarily faster than a deep V though; deep V's usually come with a few tricks such as pads, notches and/or steps....moderate V's are usually more conventional in design. Bass boats would be an exception to this.
If you want to play in the rough, like LOTO, get the deep V.
smyldoc
09-10-2006 09:53 PM
hvyhitter19
03-09-2006 01:07 PM
BZ
Northern Illinois Offshore Club
3
06-24-2005 06:26 AM
offthefront
01-06-2005 09:26 PM
MooseKnuckle
03-19-2002 10:07 PM
