tyler crockett 502efi engine upgrades ? >
Old 12-01-2003 | 01:09 PM
26sonic's Avatar
Default tyler crockett 502efi engine upgrades ?
has any one had the engine mods done on their 502 efi (cam, head work and ecu reprog) that give 75 hp-100 hp that crockett offers ?
26sonic is offline
Old 12-01-2003 | 01:19 PM
clearcut3's Avatar
PM curt on the board...I believe Tyler has done some work for him.
clearcut3 is offline
Old 12-01-2003 | 05:21 PM
Raypanic's Avatar
I had mine done, All the same changes then I had him add whipples. The standard 502 upgrade produces about 500 Hp.
He raises the compression slightly, different cam and bigger valves. Recalibrate ECU and I think he includes Stainless marine exhaust.
You wont be dissapointed with Tylers quality and end result.
Ray
Raypanic is offline
Old 12-01-2003 | 06:03 PM
H2Xmark's Avatar
Tyler's quotes on HP are on the low side, if he says 75 to 100 hp, it will be more like 90 to 115 , he does top notch work, a friend of mine had some engine mods sent to him for his boat, he can do turn key , are can supply you with the parts you need and are machine work.
he stands behind his work to.
H2Xmark is offline
Old 12-01-2003 | 09:18 PM
26sonic's Avatar
with these mods done can i run 89 octane fuel?
26sonic is offline
Old 12-02-2003 | 04:58 AM
H2Xmark's Avatar
I would ask tyler to be sure, he dyno's his kits and would know, he does cut the heads to raise compression but he also puts in a bigger cam with more overlap so that can lower cyl. pressure a bit.
H2Xmark is offline
29KILROY
07-31-2007 12:05 PM
29KILROY
4
07-05-2007 06:52 AM
26sonic
10-17-2006 02:57 AM
Liquid Missle
4
10-23-2005 05:18 PM
AWELSH
02-27-2003 10:33 AM
