Gen IV 454 mag question >
Old 12-02-2003 | 02:07 PM
formula1's Avatar
Arrow Gen IV 454 mag question
Anyone know if the drain holes in the block are petcocks (sp?) (like a radiator type) or more like a bolt that you need a socket or wrench to open?
formula1 is offline
Old 12-02-2003 | 02:11 PM
They are like brass wing nuts - similar to a radiator petcock but not.
I found that a 1 inch socket (or there-abouts) and ratchet will slip over the "wings" and make removal easy.
PS - its Mark IV, not Gen IV. Gen started with the V - go figure
Reddog is offline
SSComp's Avatar
Could be either depending on the year. If you are draining (for winter) assure the passage is not blocked by sticking a wire coat hanger in it.
SSComp is offline
Old 12-02-2003 | 02:32 PM
Official OSO boat whore
I generally use a small adjustable wrench on them. Be sure to save them. Those are the good petcocks and they are getting hard to find.
Cord is offline
Old 12-02-2003 | 03:03 PM
formula1's Avatar
are they towards the front or rear? btw, they are of a 1990 vintage.
formula1 is offline
Old 12-02-2003 | 04:08 PM
Petcocks in center of block jacets between3 and 5 and 2 and 4 cyclinders left and right one above oil cooler left side other 12 inches back of fuel filter and pump . Make sure put wrench on brass sleeve and also one on plug. Best to back petcock all the way out or sand rust gets in threads and next year they will be a bear to remove.
Vmax is offline
Old 12-03-2003 | 02:03 AM
Strip Poker 388's Avatar
Rob
my 1990 454 and 1997 502 mpi had the wrench style 6 sided plug.9 /16 wrench.My 2001 500 efi has the blue plastic plugs a lot easyier
Strip Poker 388 is offline
Old 12-03-2003 | 07:24 AM
Payton's Avatar
Charter Member #927
My 1991 454 mag has the plugs not the petcock.
Payton is offline
98itrwhite
18
12-15-2007 04:30 PM
TJC510
2
09-16-2007 09:16 PM
TufEnuf
07-01-2007 11:22 AM
Ric232
8
04-13-2003 02:22 PM
mr weazelle
0
02-08-2002 08:31 AM
