Any Guesses on speed
I am currently running Merc 6a's (wet) with 598 c.i. Cobra's 1671 airlock blowers, 7to 1 comp. ratio. 92 octane. 1100 h.p. ,1050 ft. lbs of torque. 40 ft. Skater at 10,500 lbs. Current speed with 16.5x37 Rolla's is 143 mph on gps with 1oo gallons of fuel and 2 people on board. I am going to Dry sump drives, Change pullys from 9 lbs of boost to 12 lbs of boost and burn cam 2. I am also changing drives from 135 gear ratio to 124 ratio. Am thinking 16.5x35inch 4 bladers. Any guesses on speed? Motors should produce from what I am told about 1400 h.p.
Stan
Stan
I think if you plug all that back into Bams sight the computer will start to smoke and the site will crash
I am going to give ya 10-15mph increase
Jon
I am going to give ya 10-15mph increaseJon
Put your best foot forward!
Stan-
Using your existing specs and speed, according to Bam's calculator you're running 10% slip: as you said.
Using the new info: ratio and your -existing pitch-, the new speed would be about 155 at 6100 rpm. My guess is to try your existing prop before changing to less pitch. At least that will give you a base line. Here's the link:
http://www.go-fast.com/Prop_Slip_Calculator.htm
He has other "calculators" on his site too.
Due
Due
