driveshaft bellow leaking >
Old 01-23-2002 | 10:09 AM
BajaRunner's Avatar
Post driveshaft bellow leaking
I just changed out my driveshaft bellow. and I put it in the water and a small stream of water was coming in. I ran the boat for about 30 minutes, and it looked like it stopped. I got home and figured out how to get a wrench up in there and turned it another 1 and a half turns. Do you think that will stop it or was it installed wrong?
I pulled the drive and water came out and was standing inside the bellow?
Jason
BajaRunner is offline
Old 01-23-2002 | 11:44 AM
Goodfella's Avatar
GOT MERC?
Wink
I need a couple of questions answered.
When you removed your old one did you clean the area where the bellows attaches to the housing with laquer thinner? Also did you use Mercruiser bellows adhesive to install it. Also did you cote both the bellows and the area it attaches to with adhesive and let it set up before installing? One more did you install the bellows correctly? One side goes to the transom one side goes to the prop.
Goodfella is offline
Old 01-23-2002 | 12:40 PM
BajaRunner's Avatar
Post
I did not clean it with laquer thinner. I did clean it (scraped it) and wiped it down. I did use bellows adhesive, and did let it dry. Also, I did install it the correct way.
Would not using the laquer screw it up?
Old 01-23-2002 | 02:23 PM
jr
Post
I got a tip from an old mechanic. Instead of using the bellows glue from Mercruiser, use Permatex Ultra Black. It gives a longer working time. Tried it on mine and it works great.
Old 01-23-2002 | 05:33 PM
blue thunder's Avatar
Post
Did you position the hose clamp in the proper position? I believe the bellows is molded so there is only one correct way to position the clamp screw assembly. Mine is at 3 oclock - bravo drives
Dave
blue thunder is offline
Old 01-23-2002 | 07:06 PM
BajaRunner's Avatar
Post
Same on Alphas... o clock.
What i am curious about is do you think it will seal back, or do i need to redo it?
J
Old 01-23-2002 | 09:32 PM
formula31's Avatar
Post
Man I would redo it. The risk is too great. Water in there will destroy the universals and when they blow up, you do not even want to know what its gonna cost to fix.
formula31 is offline
Old 01-23-2002 | 10:03 PM
Audiofn's Avatar
Charter Member #232
Post
yup if water went in there you better get it out!!! Take is apart again and try it again. Good luck
Jon
Put your best foot forward!
Audiofn is offline
Old 01-23-2002 | 10:06 PM
formula31's Avatar
Post
did you get the correct tool to install the expander ring in the bell housing? Thats what makes the seal at that end. Also make sure the bellows is pulled in so both rings are inside the bell housing before you install the ring.
Old 01-23-2002 | 10:08 PM
Goodfella's Avatar
GOT MERC?
Angry
If Mercuiser wanted you to use Permatex black silicone they would have told all us Cert Techs to use it! Don't do it half ass use what the manufacturer tells you to use. Laquer thinner is the solvent for bellows adhesive.
