Is there anything that dissolves Silicone glue? >
Old 01-25-2002 | 01:33 PM
Raypanic's Avatar
Post Is there anything that dissolves Silicone glue?
I am re-mounting my new GPS Speedo and the previous installer used silicone glue to mount it with. Subsequently I have glue on my powdercoated trim ring that I need to get off without messing up the finish. I have carved it down with a razor knife but need to go further. Any good solution that will remove this stuff?
Thanks - Ray
[ 01-25-2002: Message edited by: Raypanic ]
Ray
Raypanic is offline
Old 01-25-2002 | 01:55 PM
rjcardinal's Avatar
Post
You can try laquer thinner. Just make sure that it doesn't eat the powdercoat first.
Ron
rjcardinal is offline
Old 01-25-2002 | 01:57 PM
Lee's Avatar
Lee
Post
Acetone
Lee is offline
Old 01-25-2002 | 02:06 PM
blown formula's Avatar
Post
Vinegar will remove silicone that is not cured....it may work on cured if the item is soaked in it. At least that cannot hurt the powdercoat.
blown formula is offline
Old 01-25-2002 | 02:12 PM
Wally's Avatar
Were doomed!
Thumbs up
wd-40 works ok for takeing glue off
or you can go over to BoatUS and get some stuff called anti-bond....works good too.
-Wally
Wally is offline
Old 01-25-2002 | 02:16 PM
Raypanic's Avatar
Post
Thanks guys, I try the Acetone first as I have some here.
Ray
Raypanic is offline
Old 01-25-2002 | 02:53 PM
Brad Perry
Post
3m adhesive remover is the only thing I have seen remove dried silicone, had to see it to believe it, and it is safe for almost all finishes. Any auto parts store has it. Kind of like mineral spirits, but stronger.
Old 01-25-2002 | 03:00 PM
KCHOTBOAT's Avatar
Charter Member #737
Post
I have used acetone on all my powercoated parts. My friend owns a powercoating business and that is what he uses to clean the tape residue off the new parts he does.
KCHOTBOAT is offline
Old 01-26-2002 | 12:23 AM
Mr Gadgets's Avatar
Charter Member #601
Post
Raypanic ,
If you use your thumb and press a bit you can sometimes roll the RTV off a slippery surface such as power coating. Takes some elbow grease, but I have done it. On a trim ring that wouldnt be that much work.
Good luck, let us know what works..
Dick
Mr Gadgets is offline
Old 01-27-2002 | 10:40 AM
Mr Gadgets's Avatar
Charter Member #601
Post
Brad,
I bought a can of the 3M adhesive remover, now to find some dried silicon and see how it works..... Thanks..
Dick
