Vortec head on a Mark IV block? >
Old 12-21-2003 | 10:53 AM
Question Vortec head on a Mark IV block?
Did a quick search on vortec heads and couldn't find the answer to my question. I've always read that you couldn't put Mark IV heads on a Gen V big block because the coolant holes are shaped different. Also read that GM corrected this problem with the Gen VI big block. I'm wondering if you can put a vortec head on a Mark IV block. Anyone ever tried this?
bago Baja is offline
Old 12-22-2003 | 02:49 PM
I dunno if they fit or not, but I wouldn't bother. I put a set on my Gen VI, and didn't really pick up a whole lot, maybe 2 mph max. The real issue came with the compression. It detonates on anything less then 91 octane, and that's with the timing set at 30 degrees total advance..
pay a few hundred more bucks and pick up a set of merlin ovals....
just my 2 cents worth.!
Madmax is offline
Old 12-22-2003 | 05:57 PM
I figured the static compression ratio would go up to 9.2 or so with the 100cc chambers. Thought this might be a good thing but sounds like you had a problem. Do you think you were maybe a little lean with the vortec heads?
Old 12-22-2003 | 06:44 PM
You're supposed to run no more than 28 degrees total advance with the Vortec heads!
bobl is offline
Old 12-22-2003 | 07:54 PM
That explains the detonation. 28 degrees because of the static compression ratio?
Old 12-23-2003 | 09:14 AM
The Vortec heads in both small and big blocks have fast burn combustion chambers. They don't require ignition as early as conventional heads. 9:1 is the stock compression and should work with 87 octane. You can raise the compression and run higher octane but the timing requirements don't change. In fact, while doing some testing on a MPI vortec engine, the stock Merc setup was only running about 24 degrees total timing. We modified the engine and reprogrammed the ECU to end up at 28 degrees maximum.
bobl is offline
Old 12-23-2003 | 10:24 AM
JimV's Avatar
The vortech heads need porting to make them work. Chamber work, full exhaust port, bowl port on the intake would be the minimum.
JimV is offline
DonMan
20
10-19-2004 01:20 AM
olysan
4
12-27-2002 11:58 AM
TomZ
1
07-11-2002 09:43 PM
bobl
4
01-16-2002 11:15 AM
