502 Oil System >
502 Oil System
502 Oil System
Old 01-26-2002 | 07:53 PM
hondatv's Avatar
Question 502 Oil System
I have a 95 502 MPI mag and would like to put the oil filter back on the block and use the 2 block taps for my oil cooler. Anybody running this type of system ? I do have oil temp problems when running wide open with the current factory system. Does anybody know what relief valves I should use or block off ? I would like to keep the oil going through the cooler and filter at all times.
hondatv is offline
Old 01-27-2002 | 11:06 AM
Mr Gadgets's Avatar
Charter Member #601
Post
The oil line plumbing in the block on the Gen V and Gen VI is not large enough to flow enough oil... If you are having oil temp problems.. again do a search on the subject.. There are some very good threads on this..
Answers to where to monitor your oil temp and oil coolers and all of that.. There is a wealth of knowledge in this board..
Good luck..
Dick
Mr Gadgets is offline
Old 01-27-2002 | 04:25 PM
tn
Post
What type of oil—what viscosity—are you using? And, is it conventional, synthetic blend, fully synthetic, or “premium synthetic”?
Old 01-27-2002 | 08:32 PM
CheckmateF1's Avatar
Charter Member #355
Post
Do not use the "cooler" ports on the block. They are too small (3/8"npt) for marine use. You need at least 1/2" lines and fittings for you oil system.
I agree with Mr Gadgets.....Do a search on this subject. Lots of info!!
Eric
Boatless in Texas......for now
CheckmateF1 is offline
Old 01-28-2002 | 09:25 AM
Brad Perry
Post
The Merc block already has the 30psi bypasses installed. All you have to do is use a sandwich adapter between the filter and the block with 1/2 npt fittings and you'll be there.
Old 01-28-2002 | 05:53 PM
hondatv's Avatar
Cool
Thank you all for all the info. Gadgets - you're right that there is a lot of info on the board - being new I'm just finding my way around. Brad & Check that is what I'm trying to do - very helpful. Like your motor Brad. Tel - I running Castrol GTX SAE 40.
Thanks alot guys - keep up the good work - safe boating to all.
hondatv is offline
Formula311-SR1
4
09-06-2006 09:52 AM
RLW
21
08-30-2005 09:27 PM
JJONES
5
07-05-2005 02:12 PM
Fast Shafts
8
02-07-2005 08:18 PM
dennis rider
6
06-11-2003 06:53 AM
