speed formula
Old 12-22-2003 | 05:59 PM
Formula Outlaw's Avatar
Question speed formula
Can somebody please post the formula/equation used to calculate top speed? I know it's prop pitch times rpms minus something but I can't find it anywhere. Thanks....
Formula Outlaw is offline
Old 12-22-2003 | 06:35 PM
lucky strike's Avatar
This may help.
http://www.go-fast.com/boat_speed_predictions.htm
Go to speed calculator on the bottom.
LS JR.
lucky strike is offline
Old 12-22-2003 | 06:45 PM
Cool
This has always worked for me:
rpm X pitch X ratio X .00094697 minus slip. If you are using a bravo type drive, be careful with your ratio number, example; if you have a 1.5 gear, the multiplier is .667, if you have 1.36 then the multiplier is .735. Your big problem is determining slip. Thats another whole story. Slip is horrendous as a boat accellerates. ie, a freiends K boat turning 7600 with 54% over drive and 16 pitch prop, calc's out 177 but was radar'd at 145 on a
short straight. At approx 12% slip it may actually go over 155. Good luck...
burtandnancy is offline
Old 12-22-2003 | 08:37 PM
Thanks guys....
Old 12-22-2003 | 10:11 PM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
Another way is RPM / gear ratio x pitch / 1056 - percent of slip.
So if you are turning 5500 RPM with a 1.5 gear and a 32 pitch prop with 12% slip your formula is as follows
5500/1.5 x 32/1056 x .88 = 97.78 MPH
The best way to find your slip number is to go run the boat and use the above formula without the slip factor just stop after you divide by 1056 then take the actual speed of your boat and divide it by the number from the formula.
Say it ran 97.78 and the number is 111.11
you take 97.78/111.11 = .88 which is 12% slip
Hope this helps
Sean
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
darell
02-15-2008 09:37 AM
CcanDo
8
07-12-2006 12:17 PM
Rebel_Heart
8
03-04-2006 05:36 PM
thedonz
12-12-2003 04:09 PM
