garnin 180 powers off in rough water
Try going on the Garmin Web page and see if there is any issues on that particuliar unit. Also you may be able to download software changes that they have made. All of that is free and can be done at home.
My new 182C shuts off when I hit the trim at idle (see thread in the Formula forum - electrical bug). Will look for causes in the spring when she comes back out of storage. Suggestions made have been bad ground connection somewhere and high current draw from bad trim pump. Let me know if you fin the problem.
Run your ground and power directly to the battery and you will probably solve your issue. My 162 and my depth sounder did the same thing until I ran common wires for them and a couple of other things. Get them off your ignition circuit if that's where it's drawing power.
