Need help finding Scarab parts
I have an uncle that is looking at purchasing a '91 34' Scarab Super Sport center consol. The boat is missing both deck hatches and the three piece cabin door. Any idea where I could find replacements? Any and all help would be appreciated.
When I was looking for parts ,,, we hooked up with Florida Tank and Marine ,,, they buy the old molds from Wellcraft and other companys ,,, then make the doors , windshields , and tanks for older boats ,,, I dont have there numbers but I am sure some one on the board will have it ... the products were ok,,, I had to do a little grinding to make them fit but it was better than starting from scratch.. Hope this helps ...
RHC
RHC
You can contact Wellcraft. They will probably make what you need if you are really desperate. The only problem as you know is they have killed the Scarab line. First you will get a song and dance about having to find the molds for a discontinued boat and then they will try to charge about 3 to 4 times more than it is worth to avoid doing the work. You probably ran into this already. Good Luck and if you find someone reasonable could you please post it.
