Nothing else to do......so I fired up the boat. >
Old 12-30-2003 | 06:12 PM
97BossHammer's Avatar
Default Nothing else to do......so I fired up the boat.
Off all this week and got a little bored, so I fired up the boat just for kicks. Now I wish I didn't.......no water coming out the exhaust......ah new impellar time. OH well, at least I'm finding out now instead of in the spring.
97BossHammer is offline
Old 12-30-2003 | 06:20 PM
TEAMBAJA's Avatar
Did you hook the hose up?
TEAMBAJA is offline
Old 12-30-2003 | 06:28 PM
I too got bored so I went for a ride. Since it was in the mid 60's I said what the heck!
Vyper340 is offline
Old 12-30-2003 | 06:29 PM
WARPAINT's Avatar
Hook the hose up is great but did you turn the water on?
WARPAINT is offline
Old 12-30-2003 | 07:06 PM
gdfatha's Avatar
My EX got the Sleekcraft
I used to do that once a week during the winter...A 455 tricked Olds sounds awesome in a garage..but I hooked up the hose and turned on the water..
gdfatha is offline
Old 12-31-2003 | 12:30 PM
wasn't on the hose.......boat ramp is across the street so I just got the drive wet and fired her up. Dang impellars.
Old 12-31-2003 | 12:42 PM
cigarette1's Avatar
Member #2 ....Jeeezz
You need to make sure the boat is backed in enough to have the seawater pump at or below the water level. I don't think the seawater pump will pull water up a dry hose.
G
cigarette1 is offline
Old 12-31-2003 | 12:52 PM
Roger 1's Avatar
G
I agree. If you did`nt need an impeller before, you do now.
Roger 1 is offline
Old 12-31-2003 | 01:48 PM
magnum27's Avatar
G
Yes it will, when I winterize the engine, all I need to do is hook up the muffs to a hose that is in a five gallon bucket of RV antifreeze and start the engine. The sea water pump will suck it dry in seconds. when the pink stuff comes out the tailpipes, then it is winterized. Of coarse I warm the engine up first with the water hose to open the thermostat, then go to the antifreeze. Now on an alpha drive, it will not suck up the water on it's own. That is when I use a bilge pump to push the antifreeze through the drive.
magnum27 is offline
KNOT-RIGHT
02-01-2007 09:48 AM
Ms PatriYacht
06-26-2006 03:10 PM
dreamer
05-09-2005 06:15 PM
Allan4
Baja
2
04-14-2003 09:44 AM
