Trailer Lights Freaking Out, any ideas? >
Old 01-01-2004 | 10:20 PM
Formula Outlaw's Avatar
Question Trailer Lights Freaking Out, any ideas?
Okay, here's what happened going home tonight. When I turn the truck lights on the trailer lights come on. When I hit the brakes, the rear trailer lights go out. When I hit a turn signal or the flashers the rear light/lights go on and off, not on and then get brighter. I have a 01'Dodge with the factory trailer plug that the boat trailer light plug plugs into. Did that make sense?
In other words, the factory plug can only plug in one way because of the little rectangle "key" and the trailer lights can only plug into it one way because of the typical I male/3 female "contacts".
With the truck lights off, when I hit the brakes, turn on a turn signal, or hazard, nothing.
Any guesses?
I hate electrics.........
Formula Outlaw is offline
Old 01-01-2004 | 10:35 PM
Sydwayz's Avatar
Forum Regulator
Sounds like the ground is reversed somewhere. Its not hard, but I think you are going to have to stick the a meter on the plug on the truck, and make a harness; or did this JUST start happening?
Sydwayz is offline
Old 01-01-2004 | 11:31 PM
Audiofn's Avatar
Charter Member #232
You may just have a bad ground OR if you have changed lights recently make sure you did not put them in wrong or put the wrong bulbs in.
Jon
Put your best foot forward!
Audiofn is offline
Old 01-02-2004 | 05:20 AM
CAP071's Avatar
I had the same problem with an old trailer. I redid all the grounds. If you installed new lights make sure they are grounded properly.
CAP071 is offline
Old 01-02-2004 | 08:13 AM
45sonic's Avatar
Sounds to me that you have a couple of blown bulbs. They are double element and will show running lights but no turn or brake lights. Check the bulbs first then the grounds
45sonic is offline
Old 01-02-2004 | 08:27 AM
JUSTONCE's Avatar
get a dog like mine, then you wont have any lights to worry about
JUSTONCE is offline
Old 01-02-2004 | 08:56 AM
Roger 1's Avatar
Sounds like a bad ground or just bad connections. I solder and shrink tube everything. If you have the crimp type connectors on the trailer, that would be the first place to look.
Roger 1 is offline
Old 01-02-2004 | 09:06 AM
impulsive's Avatar
Definatley a bad ground. If the wiring on the trailer is old and crapy don't even mess with trying to find the bad ground. Rip all the wiring off and start from scratch. I know it sounds crazy, but in the long run it will save you alot of headaches.
impulsive is offline
Old 01-02-2004 | 09:19 AM
Roger 1's Avatar
What he said!
Roger 1 is offline
Sounds like they are operating properly. I think that trailers are shipped from the factory with lights like that!
Horseplay is offline
