Fluid Damper
Any harmonic balancer should be installed and removed with the proper tools.
And I don't mean a hammer or pry bar.
Some classes of NHRA racing require a Fluidamper or ATI balancer. The stock balancer can come apart and fly around. The rubber sandwich between the hub and outer ring can/will fail from extended high rpm use. Sometimes the outer ring will rotate throwing the timing marks off.
there nice but really not need for 5000rpm motors.
Originally posted by mcollinstn
Still being made.
ATI or Fluidampr. Good money spent. Do it. Dont go to one of the import fluidampr copies. ATI or Fluidampr.
Still being made.
formula31, check these articles out. They may help you understand just what the harmonic balancer does.
The Damper Dance
Weighty Issues
The Damper Dance
Weighty Issues
