NEW 30 Eliminator Daytona-PROPS? >
Old 01-06-2004 | 03:51 PM
Default NEW 30 Eliminator Daytona-PROPS?
Hay Guys,Just bought a new Eliminator 30 Cat and ready to go fast.It has a pair of 800s in it and runs around 130(so far) with Bravos.HAS anyone tried the Hydromotive 5 blades yet.I have heard good things about them and looking for some first hand results.I have 1.36 gearing,sportmasters and rev limit about 5800 right now.Also,any 4 blade Hydromotive users vrs 4 blade Bravos?Thanks!!
HOT BLOODED is offline
Old 01-06-2004 | 04:20 PM
throttleup's Avatar
Your props went out today. I reworked them a little before we sent them out. Let me know how they run. Safe testing.
Matt
throttleup is offline
Old 01-07-2004 | 10:30 PM
HOUSTONPROP's Avatar
Default CUSTOM BLUEPRINTED
HYDROMOTIVE FOUR BLADE BLUEPRINTED BY ,
HOUSTON PROPELLER,also check with eliminator30 mike he can probably give you some good advice.
HOUSTONPROP is offline
Old 01-08-2004 | 12:07 AM
Daytona30mike's Avatar
HOT BLOODED:
I have an 30 Eliminator Daytona with twin 800 horsepower all aluminum naturally aspirated motors with Imco standoff boxes and drives. My boat is lighter than most and had problems with to much stern lift with Bravo 34" props. I made arrangements with Houston Props
to have them reworked to reduce lift, add one more inch of pitch and lab finish. They are very knowledgeable and are able to change what does not seem to be working right for each application. I would at least give them a call and you will see what I mean.
If I can be of any help with questions you might have, don't hesitate to post and we can compare boats.
Thanks,
Mike
Daytona30mike is offline
Old 01-08-2004 | 06:40 AM
throttleup's Avatar
Just got word yesterday, I will have two sets of Prototype props from Hydromotive. These props are 5 blade props, similar to the P5 but have greater blade surface area.
I will have them in both 32 and 33" pitch. Since the 30 Eliminator generally like a stern-lift type prop they may work well. We have found, on the larger cats, that they like a little more blade area than the P5 has, this is a prop we have been working with Hydromotive on through the winter and they have just been cast, at our request.
I already have prototype props with the increased blade area in 31 pitch and they are ready for testing. We have the only prototypes of this prop in existence. After we finish our testing with Hydromotive in February they will become available through Hydromotive later this season.
Another option for a 5 blade that may work in your case, Daytona30Mike, is the P5X. We have the only prototype from Hydromtive. We will have it available in the low 30 pitch range by Feb. Again we will have the only prototypes of this prop which will also become available later this season.
Matt
Old 01-08-2004 | 06:48 AM
throttleup's Avatar
daytona30mike,
I would also like to extend an invitation to you, as I did to hotblooded. During the week of Feb 8 the owners of Hydromotive will be at Throttle Up testing props with us. We will have all of their new props, plus the new Merc 5 blades as well as the Bravo 1's. This would give you an opportunity to try the P5, P5X, P5 plus, Merc Maximus, Merc Bravo 1, and Quad 4X. We have many racers scheduled for testing this week. We will be testing boats in the 28"-36" pitch range. You will have an opportunity to try props that are not even on the market yet.
We are in St.Petersburg, if you are interested give us a call.
Matt
877 842 6855
Old 01-08-2004 | 11:11 PM
Default thanks guys!
Looking forward to some testing,just need some warm freakin weather please!!
Ptufaro
Eliminator
16
02-02-2010 08:13 PM
hardy.hardy@hotmail.
43
02-14-2008 10:22 AM
stankgilr
09-14-2007 07:40 AM
Harper220
01-08-2005 01:33 AM
vegas daytona
1
09-27-2004 07:43 AM
