Bottom Paint: Fresh or Salt?
There are a couple of dual purpose paints.
Interlux (www.yachtpaints.com) has a downloadale guide book that is pretty comprehensive as far as prep and comparison charts.
It also matters whether the boat will be on a lift or trailered versus stay in the water (most of the good paints will go bad the moment you let the hull dry - takes a recoat - just a single coat - to reactivate it).
Book spells tht out too.
If it's on a lift, you don't paint it.
If it sits in the water for over a month at a time, you need to seriously consider paint.
Yes, paint slows you down.
But not as much as the carpet that grows there without it.
