Best Place to Buy Marine Gaskets >
Old 01-09-2004 | 07:01 PM
Pat McPherson's Avatar
Question Best Place to Buy Marine Gaskets
I am in the process of tearing down my 1999 7.4MPI engine. I need to purchace a new set of Gen VI marine gaskets.
I looked at the Fel-pro web page and could not find anything. Then I e-mail with no responce.
I called Sumit they couldn't come up with part numbers.
So someone please tell me where I should buy...
Thanks,
Patrick
Pat McPherson is offline
Old 01-09-2004 | 08:37 PM
I don't know if it's the best place, but did you try cpperformance.com ? I purchased my intake manifold gaskets from them. They seem to be good quality.
Liberator21 is offline
Old 01-09-2004 | 10:49 PM
DonMan1
Default I can get you some gaskets...
I run an auto parts store. We are a Fel-Pro distributor. I can get you ANY and I mean ANY gasket from Fel-Pro. Last time I checked, I believe the Fel-Pro head gaskets for Gen VI were about $55 each. Drop me an email if interested. I am also a Sierra dealer in case you need anything else marine related.
My email is [email protected]
Drop me a note or phone....
Thanks!
Donnie
940-692-4281 home
940-521-9550 business
Old 01-10-2004 | 06:42 AM
Fel Pro 1037 head gasket. You can buy them from Jegs, summit or anywhere for that matter.
Use GM intake gasket. I don't have the number, but it's in their performance parts book.
DAVE
Dave F is offline
Old 01-10-2004 | 07:24 AM
Default gaskets
I have built several marine engines over the years and I've had great results with Mercruiser gaskets. In general there are several of their gaskets that I like the reinforcement they've made into theirs. I'm sure some will say otherwise but my personal experience has been very good with Merc gaskets. I believe they have made substantial investments making gaskets real marine gaskets. I'm sure there are other good gaskets. I've just always used Merc.
deboatmon is offline
Old 01-10-2004 | 10:09 AM
If you're going to use Fel Pro, or any other brand for that matter, make sure you use a marine gasket. The automotive gaskets that are sandwiched have steel inside, not stainless. The only automotive gasket I used on my engine was the one piece silicone oil pan gasket.
Old 01-10-2004 | 04:00 PM
Thanks for the help guys!
I would guess getting marine head gaskets and intake gaskets are the most important...
Patrick
Old 01-11-2004 | 03:50 AM
The Felpro 1037's have an Stainless core.
Griff is offline
Old 04-17-2011 | 11:42 AM
Can somebody tell me if i can use FEL-PRO 17242 on my 7.4 mpi 2000, look at the intake manifold Gasket
http://img2.wantitall.co.za/images/S...1ZRkAX45mL.jpg
and original http://www.marineengine.com/newparts...Engine=&Model=
original don't have o hole in the middle and are from other material.
What do you think?
thanks Fredrik
kafelsan is offline
Old 04-17-2011 | 12:37 PM
DAVE
Fel Pro 1037 head gasket + 1
