502efi pan to top height ?
i'll take a stab at it.... complete motor, w/standard marine exhaust is about 23.5" from crank centerline up
and about 10" or 11" down from crank centerline to the bottom of the motor mount, give or take some depending style of mount and the pallets are typically 5" or 6"... so the answer is about 40" .......... WS
He's trying to fit it in the back of his Tahoe.
Brian, you may be better off lining up a U-Haul trailer. If you drag one down with you, rent it as a local, you can probably get one for $30 bucks a day, maybe less.
