stainless marine manifolds vs. tube type(cmi,stelligs) >
Old 01-12-2004 | 06:00 PM
Thumbs up stainless marine manifolds vs. tube type(cmi,stelligs)
1000hp and over......pros and cons
SLINGSHOT is offline
Old 01-12-2004 | 06:44 PM
blue thunder's Avatar
In na applications they don't have the runner length to create the scavenging affect. Blown they are probably fine. I just bought a couple sets of the KE cast headers to try out this year. They are advertised at a 32" true runner length header.
Dave
blue thunder is offline
Old 01-12-2004 | 07:51 PM
Comanche3Six's Avatar
Stainless double wall tubular exhaust headers are prone to leak on the inside tube where the flange bolts to the head. When this happens no warning buzzers sound, there is no instrument on your panel advising you of the leak. So there you go fast as hell in your fast boat pumping water into your engine through the exhaust port.
Engines hate this. Especially Supercharged engines. When you are done screaming, you can now begin to spend a lot of money in parts, machine work and labor. Not to mention there goes the already short summer.
As you can probably tell I am not a fan of this popular type of marine exhaust.
Comanche3Six is offline
Old 01-12-2004 | 08:10 PM
Engines hate this. Especially Supercharged engines. When you are done screaming, you can now begin to spend a lot of money and labor. Not to mention there goes the already short summer.
SO MANIFOLDS THEN?
Old 01-12-2004 | 08:45 PM
yes
Old 01-13-2004 | 07:33 AM
Consider the KE header/manifolds as a good comprimise. I purchsed mine at 2k/set which is cheaper than SM and will rival tube headers in perfomance, or so they say. I will find out in the spring for sure. One of the deciding factors for my KE purchase was what Cig just said, leaks scare me.
Here is a thread we had going a while back in the TA section.
http://www.offshoreonly.com/forums/s...ickert+headers
Dave
Old 01-13-2004 | 07:37 AM
CustomRigger101's Avatar
stainless is painless bro
CustomRigger101 is offline
Old 01-13-2004 | 08:47 AM
WickedWon
On Supercharged low rpm motors tubes are for looks and yes I have them On the up side plug access is better.
Old 01-13-2004 | 11:02 AM
jrz
To quote one of our old adds aluminum melts at approximately 925 F we "heat treat" all of our headers at 1925 F with a melt temp above 4000 F , now add 200 degree saltwater and egt's approaching 4000 F. What is the value of the engine?
jrz is offline
Old 01-13-2004 | 11:37 AM
i think your temps maybe off
