Pressure Washers
We Run A Tuff it is made by Hotsy.
It is Heated up to 300degrees
Honda 13 hp gas
electric start
The heater is keroseen or deisel or #2 heat oil
it is totaly self contained other then water.
The mode # is tpg4035e
4000psi cat pump
It is overkill for are use (Auto Dealership)
But I wanted something to take care of my Marine
needs also.
I think we paid 3200
Check out
http://www.tuff-pw.com
Good luck
Gerry
Honda 13 hp gas
electric start
4000psi cat pump
needs also.
Check out
Good luck
Gerry
Originally posted by sutphen30
what are you thinking,a new business
