Performer RPM or Airgap manifold
Charter Member #818
I have a perfectly good Performer RPM manifold on my Gen V 502. Would I see any gains by going to an AirGap or something else? I want to stick with a dual plane for driveabilty and idle quality. Just wondering if I will get $250 worth of improvement or should I save my money and just buy gas. I am changing the cam anyway so now would be the time to do the manifold.
Thanks, Doug
Thanks, Doug
No. "Performer RPM AirGap" is just an updated "Performer RPM" with incrementally better runner design (not significant enough to warrant replacing) and a designed-in hollow underneath the plenum to isolate the runners from the heat transferred from the engine oil splashing from the cam and lifters onto it (which is noteworthy, but a valley splash guard will give much of the same benefit).
If I were buying new, of course I would pay the $60 premium for the newer airgap, but if I already had a P-Rpm, I would block off the heat crossover and stick a splash guard in it ($25 total in parts to do both) and rock on.
Charter Member #818
Thanks for the replies guys. I think the consensus is to stick with the RPM. My motor already has the valley splash guard so I should be OK there. I kinda wondered if there really was much difference other than the "airgap" under the plenum. I have one of the Comp Extreme Energy cams with 224/230 duration that Dennis Moore is always talking about that I bought a few years ago when I was thinking of hopping up the old 7.4L. I have to pull the engine anyway this winter to install a bigger oil cooler so while it is out I am going to change the cam, too. I need about 1.5 to 2 more mph out of the old Baja to hit 65. With any luck the cam will get me a couple of hundred more RPM.
See ya, Doug
See ya, Doug
MACDAD260, is the cam you are talking about the Comp Cams Grind# CB XE268H-10? if so I am trying one in one of my engines also.....just wondering about any reversion issues.....what exhaust are you running?.....Fred
