Effects of cold weather on boat?
Am wondering if extreme cold, such as in the northeast right now has any adverse effects on a boat's hull, drives, steering, etc?
I have purchased a boat that is up in Stratford CT right now, it's shrinkwrapped, but sitting outside, (the motor has been drained). Thanks.
If it was winterized properly you will be fine. Things to get brittle in extream cold like plexiglass and even fiber glass but you should be fine and when they get warm again they are the same.
Jon
Jon
Put your best foot forward!
If there is a little no problem. If there is a LOT then you will see the water freeze and blow the transom apart. The force of freezing water is quite awsome, cracks blocks after all.
Jon
Jon
Sorry to jump in on another guys thread, but this brings up a question I have. My boat is stored in an unheated warehouse. The engines and trannies are out of the boat and the drives have been winterized. I only have a freshwater holding tank which is empty, no head or anything else.
Last weekend when I was working in the engine compartment, there was a puddle of water in the bilge. I had previously removed all of the water a couple months earlier when I painted the bilge and engine compartment with Awlgrip.
So where did this water in the bilge come from? Do you think the fluctuations in temperature over a month or so could cause enough condensation to build up inside the hull and pool in the bilge? I'd say there was about 1/2 gallon of water.
Obviously that was an initial thought, but I couldn't find any indication of it. There are no water marks or stains on the ceiling or anywhere else on the boat, just the small puddle of water in the bilge that wasn't present a month earlier.
I was thinking/wondering if over the span of the 35' hull, that maybe enough condensation could accumulate to form the puddle?
