Fuel Guage?
Old 01-16-2004 | 12:43 PM
phastang's Avatar
Default Fuel Guage?
Went for a run this past weekend and the fuel guage is not working. It worked perfectly when I put the boat away at the beginning of November????? The guage is Gaffrig II and it is stuck on empty. Any ideas on where I should start?
Ty
phastang is offline
Old 01-16-2004 | 01:14 PM
I would call Livorsi. My 260 has Faria's and the fuel gauge stopped working at the end of the season and for 8 bucks they replaced it. I e-mailed Faria direct. Gaffrig II's are from Livorsi.
Gary C is offline
Old 01-16-2004 | 02:13 PM
mopower's Avatar
Toxic FORMULA
That's the best part of Faria guages...they're guaranteed for as long as you own them
mopower is offline
Old 01-16-2004 | 02:23 PM
Doller Offshore
ground out the fuel sender w/ the key on and see
if the needle in the gauge pegs out if it does
it's the sender if itdoesn't its the gauge
art
Old 01-16-2004 | 03:16 PM
phastang's Avatar
Thanks for the info guys. Time for testing.
phastang is offline
Old 01-16-2004 | 03:42 PM
Reed Jensen's Avatar
Does the sending unit have a float? you may just need a new float on the unit... but if it is a resistance unit... you will probably need to replace the whole thing. Just a suggestion as to where to check. Good luck.
Reed Jensen is offline
Old 01-16-2004 | 07:31 PM
Ground the fuel sender like Doller Offshore said, but also check to see if the gage has power.
Liberator21 is offline
Old 01-17-2004 | 01:51 PM
Check for good ground to sender and godd ground to tank. Any contact corrosion may cause it to read empty.
Vmax is offline
575cat
3
03-09-2008 09:06 PM
lorne
4
07-09-2007 04:16 PM
bgriff
Fountain
8
05-31-2006 07:47 AM
BAD-HABIT
9
05-06-2003 03:08 PM
buck183
Scarab
6
07-08-2002 02:55 PM
