Taking the hook out!! >
Old 01-16-2004 | 07:30 PM
Default Taking the hook out!!
I have read that on the 26ft Scarab that taking out the slight hook in the pad will help the top speed.
I have a 1988 28ft Scarab Excel which is the same bottom design and shares the same slight hook.
Should I just sand the area with 200 grit paper and fill the hook with gelcoat??
TomR is offline
Old 01-17-2004 | 01:22 PM
TTT
TomR is offline
Old 01-17-2004 | 01:38 PM
H2Xmark's Avatar
there is a great article in the march2004 issue of Family&performance boating, on page 90 they take the hook out of a scarab 22 and picked up 4 mph!!! it is 4 pages long and has some color photo's in it,
Mark R
H2Xmark is offline
Old 01-17-2004 | 04:17 PM
Thnaks Mark. I'll try to find it.
TomR is offline
Old 01-17-2004 | 06:46 PM
homan
TomR I have the exact same boat how fast are you in it now.
Old 01-17-2004 | 08:05 PM
Ric232
From what I've heard/read, you can run into some wild handling issues when you remove the hook, especially porpoising.
Old 01-17-2004 | 09:05 PM
homan,
I run a 550hp 502, the boat runs about 75mph.
I'm turning a labbed 25 pitch Mirage "plus" at between 52-5300 depending on the temp humidity etc.
TomR is offline
Old 01-17-2004 | 10:35 PM
TomR I'm over on Nantucket in the season I have a '81 26' wellcraft . I'm in the middle of a rebuild project. I stripped out every thing, motor,trans,drive Arneson #6. I'm going to try to keep it as light as possible .so I've bought a HP 350S/B to start of with. If all goes well what is happening with small cubes and BIG TURBOS is VERY interesting . Seems like you can have huge power with 200 to 300 lbs off the ass end of the hull. Anyway I took the hook out of my hull ,but I havent tried it out yet . so if you do the same we'll both find out. I have a Yamaha GP 1200 slightly hopped up. Anyway that thing porpoised so bad it drove me nuts. I tried every suggestion I got,new scoop,different ride plate,new sponsons on & on. Then aguy told me to get a grinder and to make the edges of the strakes and the back edge [bottom/transom] as sharp as possible. So I did that and it is'nt pretty BUT, NO MORE PORPOISING. I hope this follows thru on a26' hull as well as it worked on a10' hull. Any other opinions out ther on this hull??? andrewmasonsr
obads 31 is offline
Old 02-07-2004 | 10:26 AM
robyw1's Avatar
Mark R
Is this Family & Performance Boating magazine available in any bookstores? I could subscribe but would probably not get the issue with this Scarab hook article.
Roby
robyw1 is offline
Old 02-07-2004 | 11:17 AM
Roby,
I have looked in every bookstore and many Drug Stores in my town. I have not found it. If someone comes up with it could it be shared without copyright problems?
BadDog is offline
